2000 Chevy Silverado window switch clicking, window not moving?
Lance B
I rolled the window in my Silverado down today and when I went to roll it up I press up on the switch and it makes a click noise every half second or so while I hold the switch down, it doesn't sound like the motor is even trying to move.. any ideas?
all other switches work normally
switch is probably good, motors probably out. before you jump into that high priced headache i would start by checking a 50 cent fuse first though. most fuse boxes are even labeled so you can figure out which fuse it is pretty easily. if it's not the fuse then it's most likely the window motor and they aren't fun to replace so unless you're highly motivated and pretty well versed in automotive i'd say pay someone to fix it for you.
