battery has voltage..alternator good...put the key in and turn to start position all lights, dinger and gauges are flippin out...try to start and starter just clicks like low voltage....hooked up code finder and everything passed...no codes..have disconnected battery to try an reset...and tried the 10min thing..and still the same.... mechanic said it could either be my ignition switch or one of my modules...i think the BCM (body control module is bad) does that sound right???....everything in my dash lights up and gauges flip around (all of them, temp., gas, speed and rpm) there is a relay for the automated headlamps that is clicking under hood but i took out and switched with a different one and still the same....everything ran fine and i went out to eat and came back to car to start and it all of a sudden did it...i haven't done anything irregular to it..it was driving fine and when i went to leave it wouldn't start....all fuses are good...any ideas??? or were the modules might be located and how to test them?
