Matthew F
- Nov 13, 2008
My 2000 Chevy Malibu is making a fast clicking sound when you first start it. It is the same noise, and coming from the same place as the turn signal noise, but the signal is not on. It stops after about 30 seconds, but it is a very quick click sound. If you turn on the turn signal or the flashers, it will slow down the pace. Once you turn it off the fast noise comes back. No lights are blinking on the outside when this happens.
What can be causing this?
The starter has been tested and checks out. This noise is identical and coming from the same spot as the turn signal noise.
This doesn't sound like fuel pump noises. I've been there, done that. It literally sounds like the turn signal is on, except faster.
