Good Guinness To You!
- Oct 23, 2009
Ok on warm days my chevy has a problem starting. I have to press the gas pedal to get the engine to run. When I drive it after getting it started it runs perfect (not fuel pump) so it not wanting to start is an isolated issue. The only things I have done
1. replace the fuel pressure regulator
2. replace fuel filter.
Any guidance on how to get the truck running prime is appreciated.
The check engine light is not on, It was serviced for 100k miles 2 k miles ago. I'm thinking it's the injectors.
No I'm not putting it to the floor, but damn near close. I will check out the coolant sensor.
