I'll try to keep it short. Lastnight I gunned (raised the rpms high) it through an intersection so I wouldnt get stuck at a red light. Next light, I got stuck at a red. I notice immediately that my truck is running shakey. I take off and I have very low power, check engine light comes on. I run a scan, I get a P0302; Cylinder 2 has a misfire. I clear the code and drive around the block to see if i get the same code. This time I get a multiple misfire code. I run a compreesion test this morning starting at #2. According to the reading of the compression tester none of my cylinders are holding pressure which i find strange because the truck is still starting up and somewhat driveable.
What could be causing this? I thought it was the tester i was using but I video recorded the gauge while i was cranking the enigine over and saw in the video that it would flutter up to 60psi at the most.
