Hi! I'm new to this forum. Recently, I purchased a '97 Suburban from an auction. It has a few issues that need some attention. First, the fan (blower) is stuck on high with the ignition switch on. Even when it is in the low or off position it is still running high. Also, the temperature control is not functioning properly and is blowing cold in the front compartment only. The rear compartment is working perfectly with the temperature and fan. I think it is one of two things. It might be the control panel on the dash and possibly a resistor, or the door in the heater box is stuck or malfunctioning. I thought I might get a few opinions before I shell out $150+. Thanks in advance.
