1995 chevy lumina
frank1234
the problem is that the check engine light keeps coming on. when checked by a mechanic's code scanner it says the #3 tower on the egr valve is bad, i have replaced it three times but the light still comes on and it still says #3 tower is bad after mechanic reset the computer each time. 3.1 engine. does anyone have a clue?
you have to provide the code, ask your mechanic for it and then post it here
Paul Hammond
I inherited my 1995 Lumina in 2001 with 4k to 5k on the odometer. The Good. No interior rattles, all power accessories work well, and now with 72,000 miles the engine still runs like new.
WyrTwister
sorry there wasn't another forum for this car. the problem is that the check engine light keeps coming on. when checked by a mechanic's code scanner it says the #3 tower on the egr valve is bad, i have replaced it three times but the light still comes on and it still says #3 tower is bad after mechanic reset the computer each time. 3.1 engine. does anyone have a clue?
Check all the electrical and mechanical ( including vacuum ) connections to the valve .
Do a google search for the error .
God bless
Wyr
