O orllykitchens@gmail.com New member Joined Mar 19, 2015 Messages 1 Reaction score 0 Points 0 Age 46 Mar 19, 2015 #1 what is the correct timing degrees on 95 5.7 stock at 15 now but throwing code.
zora Staff member Joined Apr 24, 2012 Messages 5,519 Reaction score 139 Points 63 Mar 19, 2015 #2 what is the code? did you check the timing with the computer controlled spark disabled? you no longer have the emissions sticker under the hood which explains how to disable the computer and what the timing spec is? should be set for zero.
