1994 Suburban 1500 temp guage not working
churritos626
Hi i just bought a 94 suburban and the temp guage does not work. I was wondering the location of the ect was. Its a 5.7l v8 tbi.
And also does anyone kknow the brake bleeding pattern? I do not have my book anymore and thier is air in the brakes.
Any suggestions help.
Thanks!
replace the temp sending unit on the side of the head. will have an electrical harness plugged into it. if that does not fix it you will need to replace your dash cluster or run a single temp cluster instead of replacing the entire dash cluster. as for the brakes start at rear passenger , rear driver, front passenger and then driver for final bleed.
