1994 chevy silverado compressor wont come on?
g-p
recently had my changed out from v6 to v8 but now my compressor wont come on i juggle the wires and it spark sometimes
When You Switched The Motors Did You Take Off The Ac Pump? Take Lines Apart?
Did It Work Before You Switched Motors? If The Freon Escaped Then You Will Have To Add To Specs. More Freon For Your Pressure switch To Pick It up & It Should work. If Not Check Fuses & Make Sure Wire Is On Pump To Control Clutch Is Attached.
Best Of Luck.
