Hi this is my first thread here . The problem is it will wont stay at any rpm more than approx 15 seconds before stalling. Idle approx 15 seconds then it will die 2500 ,3000 ,1500 the rpm does not matter the same result. If you constantly work the throttle it will stay running .Its not showing any engine codes just tranny codes . This is the list of parts that i have replaced and it runs exactly the same fuel pump, fuel filter, fuel pressure regulator,fresh gas and water remover, map sensor , tps,the last item was distributor, would have been cheaper if i had just taken it to a shop . cap rotor and wires are about one year old .I have had this truck about 10 years it has always ran perfect until about three weeks ago. I did notice if i unplug the map sensor it will stay running and it can be driven without stalling just not much power .Also when it dies it does not lose voltage to the coil,the spray from the injectors decreases as it dies.I bypassed the fuel pump relay so the fuel pump stays running and the fuel spray from the injectors still decreases as it dies. Any help would be great thanks
