1990 Truck Back Fires.
smitty22
Hello. I have a 1990 Chevy 1500 5.7. When I start it, it sounds like it's back firing throught the tail pipe. Plus it's running rough. But, when it warms up, it smooths out. Any thoughts on the cause? Thanks.
when is the last time you had a tuneup, spark plugs, cap, rotor, plug wires, air filter, gas filter? Typically it would be ignition related.
Thanks for the reply. I've recently have changed everything except the air filter and fuel filter.
How many miles are on the engine?
Have you pulled the plugs to see if one of them is not firing?
Have you done a compression test?
