abpumprepair
- Nov 24, 2008
I just bought this truck. It has 150,000 actual miles. It has been in storage for the last 5 years. When I first bought it, it ran great. Now after 900 miles, it shakes at idle, misses at idle and after idling for about 4 minutes, it smokes like crazy. Blue. Give it a little gas and it clears right up, both the idleing and the smoke. I am getting 11 mpg highway as it is. 350 TBI motor. I have changed the plugs, wires, cap and rotor but nothing different... Any suggestions would be greatly appreciated.
I did just change the fuel filter but no difference. As for the valve seals..I should correct myself.. after a few minutes it smokes like crazy but if I let it idle, the smoke all disappears after about 5-6 minutes.. It does have a nasty smell coming from the exhaust, kinda gives you a head-ache if you smell it too long.
Also I should ad that once you step on the gas, all smooths out just perfectly.. I took it to the shop to get a engine code read and it say's that nothing is wrong.. also, the catalitic converter has been removed because I thought it may have been clogged.
went out this morning, started in and within 15 minutes the temp guage was up to 260 degrees at idleing, once I gave it some gas, it went right down to 195 .. head gasket??
