HomesteadChevyMan
- Jul 25, 2022
The high beam switch is located on the floor and when I press the high beam switch the right high beam turns on & right low beam goes off.
When i turn off the high beams the low beam goes back on but looks dim.
The left low beam turns on with the high beam and the left low beam stays on when the high beams turns off.
Why is the right low beam going off when the high beam switch turns on. Why does the low beam looks dim when it turns on when the high beam switch get turned off.
