08 malibu ls 4cyl coolant guage not working p0128 please help
davetheman81
Any input on this guys would be great.... i have been fighting with my wofes malibu for months trying to fix it heres the deal. 1.Check engone light p0128 - thermostat issue
2. Temperature gauge reads 0 all the time
3. Ac wont work becouse the p0128 cuts off the ac incase the car is overheating.
4. Cooling fans come on and stay on with ignition
Things i have replaced
1.Thermo stat twice
2. Coolant temp sensor
3. Flushed coolant and burped
4. Replaced ecu! Had dealer reflash
5. Battery
6. Coolant fan relays
When i unplug the ecu and plug it back in or the battry, or delete the check engine light the car acts fine for 5 to 10 mins ac works no cel and temp guage works ... then temp needle drops to cold, check engine light comes on, no ac...
Very agrivating only thing left i can think of is a chewed up wire somewere, all the cooling fans work.
But i conducted an experiment i took a measurement of the resistance of the coolant temp sensor out of the car and got 2.24 k ohms which is correct. I then dropped it in hot water and whatched the resistance change correctly. I then in stallled it in the car and with the key off its 2.24 k ohms but key on it goes to .01k ohms and wont move and i measured it at the ecu and sensor. Thanks so much!
the code also points to the intake air temperature sensor and other issues. If you dont want the dealer to work on the car how about a private shop with the proper diagnostic tool to interface with the ecm and actually run tests rather than replacing things.
http://www.obd-codes.com/p0128
