07 cobalt is leaking water from the dash
ozzy88m
My dash is leaking water into my floor boards and when i turn corners it makes this gurgling sound, my a/c still runs cold and blows air out like it should. what could be the problem?
are you sure it's not antifreeze indicating a leaky heater core? If water, you could have a clogged A/C drain, if you have a sunroof the drains could be clogged, or the seal around the windshield could be bad. If it is not the heater core or A/c drain, run a water hose on spots of the car till you find the source of the leak
Hi there,
Sorry that you have this issue with your Cobalt. If you want to send me your VIN I can check to see if there are any recalls or bulletins listed related to this issue.
Amber N.
Chevrolet Customer Care
I'm more inclined to agree with Zora on the clogged a/c drain. Not an uncommon thing to happen on any car.
