07 chev Suburban driver tail lights
suburbannik
I have a 2007 chev suburban that the driver tail lights, I mean running lights do not work. Also the license plate lights don't work. All other lights work. I saw alot of videos of poeple putting in the tail light circut box, but I can't find out where it is located on the 2007. On line all the sales for the circut box are for 02-06. Anybody have ideas??? THANX!!
Before anything else did you test the appropriate fuses on both the interior and engine compartment fuse boxes?
You are sure it's a box and not a board?
I'm not sure it even has a circuit board. Can't find it, or one on the suv. Lights don't have a board on 07. Possibly the connectors need cleaned. Thanx..
Did you remove the lamp assembly and look at the back to see if there is a circuit board?
Yes, I did. Mine just has the lens and a harness that the bulbs go into. No board inside. Maybe BCM, but I have no other electrical problems. Possibly just a bad wire going to that side.
