06 Cobalt Lt
DMC
Left front brake is locking up intermittently and causing a terrible vibration when driving. Calipers, pads and rotors have already been changed. Has anyone else had this problem ? What had to be done to fix it ?
did you check the wheel bearing?
DMC,
I apologize for your frustrations. Unfortunately I don't have technical information. If you haven't worked with the dealer I would recommend asking them. Please feel free to message me directly. Any updates on your situation are appreciated.
Christina
GM Customer Service
did you check for a internally collapsed rubber hose
Ditto on what Zora said. Simple to check. Just start at one end and pinch the hose from that end to the other. If you find a spot you can pinch it together, there's your problem. They break down internally so you won't just be able to look at it and tell. They're not that hard to replace either. Just a little messy.
