05 chevy silverado with weird starting problem?
Julian P
truck has a p0342 code for a low voltage cam sensor. i recently put gas in it. but i just came back from some really crapy gas station in the middle of nowhere. could it be because of this. its a 6.0L v8. car with have long cranks. and after so many starts it will finally start. its like out of every 3-4 starts it with actually start. and sometimes when its doesnt start it will still run. really weak though. like if it was dieseling or like if from just the compression of the gas and air in the cylinder still kept it running. like a diesel motor. its wierd. anyone know what it is?
engine will turn over!!! long crank but no start sometimes. other times it will start like normal!
Could be a bad fuel filter or fuel pump.
