'01 2500Hd 4wd problems I've Replaced everything new!!
phil816
ive read many posts to help me get to where i am now but still cant get this figured out.. im in this transfer case $1745 and still not working. ive heard of people spending much more but dident plan for this.
i bought this truck knowing the transfer case did not work.
'01 Silverado 2500Hd 4wd 6.0L Gas (3-button electric switch)
I bought a reman np263Hd transfer case then bought a encoder motor then front axle actuator and the dash switch.
i hear the case switching after i press the button but never engages all of the way the light just blinks and goes back to 2wd. before i bought the switch i took to a shop they hooked up scanner and believed the switch wasnt getting the signal to front actuator now after replacing the switch im lost. ive read something about the front diff not locking??...
before i bought this new switch while i was in the shop we put truck on the lift and had all wheels in the air i saw the front driveshaft turning looks like things are engaging that far foward.
i know just about everyone has problems with nbs 4wd systems thanks in advance..
I would have the dtcs checked and cleared. if there is a stored trouble code the bcm may not let the 4 wheel drive work. you might have fixed the problem and the vehicles computer dosent know it.
