chevy forums   chevy forums
Go Back   Chevy Forums > Chevy Forums - Cars > Chevy Lumina Forum
Chevy Lumina Forum Discussions regarding the Chevrolet Lumina
Chevy Forum: 1995 Lumina turn signal/hazard issue
Reply
Thread Tools
  #1
Old 11-25-2018, 05:19 PM
thebull55 thebull55 is offline
Junior Member
Default 1995 Lumina turn signal/hazard issue
Hello, new guy on the block.
I am working on my daughter's 1995 Lumina 4 door sedan 3.1L. She was driving and the alternator died so she stalled out and lost everything. I replaced the alternator and all seemed well except she now doesn't have turn signals or hazards. They don't light up or anything. I checked the fuses and they are good. I changed the flasher and nothing. I tried to check the power at the flasher plug and couldn't get anything there. The only thing else I see now is the turn signal switch?
Does that cover the turn signals and flashers? Also, am I missing anything else worth checking into?
I appreciate any advice or help. Thank you!
  #2
Old 11-26-2018, 10:35 AM
zora zora is offline
Administrator
Default Re: 1995 Lumina turn signal/hazard issue
the flasher and hazard use different fuses, you checked both of them?
you referred to the owners manual to located all the fuses related to the signal/hazard?
are you sure they worked before the alternator failed?
http://www.vadengmpp.com/owners-manu...let-Lumina.pdf
  #3
Old 11-27-2018, 01:59 AM
Junior Member
I did check both fuses and they are good. They were working before the alternator change.
I am thinking on trying the switch. It looks like the one switch covers both.
  #4
Old 12-14-2018, 04:09 AM
Junior Member
I ordered a switch to try that since I can't find anything else. Going to install this weekend. Odd thing...I was following the car last night and out of habit she flips on her turn signal. When she turned on the left turn signal, the left brake light dimmed like it would when it flashed. It just stayed dim. I had her try the right, same thing. If she hits the hazards both dim. I replaced the flasher and no help.
Does that lead to any thoughts?
  #5
Old 12-14-2018, 11:09 AM
Administrator
check the ground connections.
you are sure the correct bulbs are being used and they are installed correctly?
  #6
Old 12-19-2018, 02:36 AM
Junior Member
I installed the switch over the weekend and we have turn signals and flasher!! That was a bitch to change, but got it done.
Thanks for the input.
  #7
Old 12-19-2018, 11:28 AM
Administrator
good to hear you got it fixed
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sponsors
cars connected social network cars connected social networking app for ios cars connected social networking app for android
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Miss the Chevrolet SS? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
