chevy forums   chevy forums
Go Back   Chevy Forums > Chevy Forums - Cars > Chevy Aveo Forum
Chevy Aveo Forum Discussions regarding the Chevrolet Aveo
Chevy Forum: Temperature Needle and LED brake lights
Reply
Thread Tools
  #1
Old 03-12-2014, 12:07 AM
metroII metroII is offline
Junior Member
Default Temperature Needle and LED brake lights
For some odd reason, my 11 Aveo has been acting strange with the needles, after i put LED bulbs in the tail lights. It started making the radio go dim when i stepped on the brakes, , so I took the bulbs out, and the radio is fine... But Now, as of today, my temperature needle is marking as if the car is a 3rd of the way hot. Coolant is fine, liquids are fine, no problems. Now about 30 mins ago ( 1255am as i type this) the temp needle is at the last white line, before the red line. But, car is running fine, coolant is flowing no problem, and the fans are on. When I turn off the car, the needle does not go all the way down, when the car is off, past the C mark...
Previously, the needle would get stuck between the cold and first temperature line when i turned off the car.
Sorry for the typos, i just ran to get my best friend from the hospital, and noticed that. ( thankfully she is fine just a muscle spasm)
Any idea to what that is?
All answers appreciated.
  #2
Old 03-12-2014, 09:05 AM
zora zora is offline
Administrator
Default Re: Temperature Needle and LED brake lights
Have you had the battery load tested and checked the alternator output?
  #3
Old 03-14-2014, 12:02 PM
Junior Member
Everything is fine and charging the way it is supposed to.
  #4
Old 03-14-2014, 12:21 PM
Administrator
Then the gauge appears to have an issue since it never goes back to cold.
  #5
Old 03-15-2014, 10:29 PM
Junior Member
Well i took out the cluster. I noticed when i put the cables back in, something makes the needles go crazy when the purple plug is put back in. So I put everything normal, and it worked fine. Until today when it did the raise again. Is this something normal for the gauges to act like that on chevys? I had a similar problem on my 94 Astro and noticed other Chevys have gauge problems also....
  #6
Old 03-16-2014, 08:48 AM
Administrator
the cluster panel can go bad and typically people find replacements in a salvage/junk yard
  #7
Old 03-18-2014, 06:43 PM
Junior Member
Im looking on line because the Aveo 2nd gen here, is not a big car. It is more seen as Sonic
  #8
Old 05-08-2014, 07:47 PM
sander sander is offline
Junior Member
Seems like the gauge or the temp sensors is the culprit in your problem.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sponsors
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Miss the Chevrolet SS? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
