chevy forums   chevy forums
Go Back   Chevy Forums > Chevy News Forum > Chevrolet News Forum
Chevrolet News Forum All news and information regarding Chevrolet in the automotive industry.
Chevy Forum: The 1962 Black Corvette is Out of the Museum Sinkhole
Reply
Thread Tools
  #1
Old 03-05-2014, 10:47 AM
News Man News Man is offline
Member
Default The 1962 Black Corvette is Out of the Museum Sinkhole
The crew responsible for extracting all of the historic American performance cars from the sinkhole under the National Corvette Museum was hard at work today – this time removing the black 1962 Chevrolet Corvette which was perched precariously along the side of the hole in the Earth with a 10,000lb slab of concrete pressed against the front end.
The 1962 Chevrolet Corvette was the most difficult car to remove as the first step of the extraction process. After spending day 1 removing the 2009 Blue Devil and the Ruby Red 40th Anniversary Edition 1993 Corvette – both of which were as simple as lifting them out of the hole – day 2 saw a much greater challenge.
The 1962 Corvette didn’t fall nearly as far as the other 7 Corvettes in the massive sinkhole, but when it fell a large portion of the Skydome floor ended up pressed against the front end of the classic Vette. Also, the 1962 Corvette was part of a “lift display” under the 1993 Ruby Red Corvette and that lift also fell into the hole. The team was concerned that if they simply pulled the 1962 Corvette away from the 5 ton concrete slab, the sheet of manmade rock could shift and either cause more damage to the 1962 Corvette or it could fall into the hole and cause extensive damage to one of the other 5 cars still buried below. Because of those concerns, the team had to devise a plan to secure that concrete slab before moving the 62 Corvette. In addition to the headache of dealing with the concrete slab, the type of wheels and the angle at which the 62 Corvette was propped made it impossible for the extraction crew to lift this Corvette by the wheels like they did with the first two cars that came out of the hole yesterday.
Once the team had drilled a hole through the concrete slab and secured it – as well as removing the crumpled lift – they were able to remove the hood and run lifting cables around the front portion of the chassis which holds the engine in place. Thick strips were wrapped around the engine mounts and the radiator support, then attaching crane cables to those straps so that the 1962 Corvette coule be lifted out nose first. Once up and out of the hole, the black 62 Corvette was carefully set on all four wheels. While it did not start and drive away like the 2009 Corvette, the team was able to push it easily out of the opening in the side of the Skydome.
"The recovery of the first three cars went flawlessly, and the cars are in remarkably good shape," said John Spencer, manufacturing integration manager for Corvette. Spencer. "Unfortunately, the remaining five cars are either partially or totally covered in debris. We expect their recovery will be much more challenging, and the cars to be in much worse condition."
The extraction went as well as the team had expected, but the removal of the other five historic Corvettes will likely be much more difficult. With the first three, the team was able to examine the cars from almost every direction to lay out their extraction plan, but the next five are either totally or partially buried in debris, dirt and other Corvettes. Because of this, the team will have to move forward in careful stages, removing layers of debris as they get closer to each car.
Check out the time lapse video below to watch the extraction process of the 1962 Chevrolet Corvette from the National Corvette Museum sinkhole and stay tuned to TorqueNews.com for news on every step of the NCM repair process.
Reply
Tags
corvette
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sponsors
Copyright ©2000 - 2020, vBulletin Solutions Inc.
chevyforum.org recognizes that "Chevy", "Chevrolet", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. chevyforum.org is not affiliated in any way with the General Motors Corporation, Chevy, Chevrolet or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 Madison Ross Media Group. All rights reserved. Content published on ChevyForum.org requires permission for reprint.
Miss the Chevrolet SS? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7. The Kia Telluride is a mid-size SUV similar to the BMW X5...
