chevy forums   chevy forums
Go Back   Chevy Forums > Chevy Forums - Cars > Chevy Camaro Forum
Chevy Camaro Forum Discussions regarding the Chevrolet Camaro
Chevy Forum: 2016 Chevy Camaro Specifications
Reply
Thread Tools
  #1
Old 05-16-2015, 10:15 PM
Chevy Forums Chevy Forums is offline
Administrator
Default 2016 Chevy Camaro Specifications
2016 Chevy Camaro Overview
Body style / driveline: four-passenger, front-engine, rear-drive coupe
Construction: unitized body frame, one- and two-sided galvanized steel
EPA vehicle class: coupe
Manufacturing location: Lansing, Mich.
Engines
2.0L Turbocharged I-4 VVT DI 3.6L V-6 VVT DI 6.2L V-8 VVT DI
Displacement (cu in / cc): 122 / 1998 222 / 3640 376 / 6162
Bore & stroke (in / mm): 3.39 x 3.39 / 86 x 86 3.74 x 3.37 / 95 x 85.6 4.06 x 3.62 / 103.25 x 92
Block material: cast aluminum w/ cast-in-place iron bore liners cast aluminum w/ cast-in-place iron bore liners cast aluminum w/ cast-in-place iron bore liners
Cylinder head material: cast aluminum cast aluminum cast aluminum
Valvetrain: DOHC, four valves per cylinder, continuously variable valve timing DOHC, four valves per cylinder, continuously variable valve timing; Active Fuel Management overhead valve; two valves per cylinder; Active Fuel Management
Fuel delivery: direct high-pressure fuel injection direct high-pressure fuel injection direct high-pressure fuel injection
Compression ratio: 9.5:1 11.5:1 11.5:1
Horsepower (hp / kW @ rpm): 275 / 205 @ 5600* 335 / 250 @ 6800* 455 / 339 @ 6000*
Torque (lb-ft / Nm @ rpm): 295 / 400 @ 3000-4500* 284 / 385 @ 5300* 455 / 617 @ 4400*
*SAE certified.
Read more...
__________________
Want to be connected with everything automotive in your area? Check out the Cars Connected app today!
Get your next Chevy for the lowest price possible! Go to TrueCar.com first!
  #2
Old 03-29-2016, 07:15 AM
emmagloor emmagloor is offline
Junior Member
Default Re: 2016 Chevy Camaro Specifications
Wow,This is really a great car.I am waiting for this car.Thanks!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sponsors
cars connected social network cars connected social networking app for ios cars connected social networking app for android
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Miss the Chevrolet SS? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
