chevy forums   chevy forums
Go Back   Chevy Forums > Chevy Forums - Cars > Chevy Cavalier Forum
Notices
Chevy Cavalier Forum Discussions regarding the Chevrolet Cavalier
Chevy Forum: 98 chevy cavalier overheating and running towards the hot ?
Reply
Thread Tools
  #1
Old 02-04-2009, 10:32 AM
Blessed1 Blessed1 is offline
Junior Member
Default 98 chevy cavalier overheating and running towards the hot ?
I have a 1998 Chevrolet Cavalier. When I first got it their was no heat and it was running towards the end of the heating line. Replaced the thermostat(checked the old one afterwards found out it really was junk) and flushed out the hoses, this got the heat working. We flushed the radiator and filled it with coolant. It has an electric fan, the fan is indeed working. Today the car started to go past the white line and towards the red so I pulled it over. When it gets to that temp, everything gets hot EXCEPT the radiator. My heater is working good now, so we dont believe it is the heater core, but are wondering if anyone has any suggestions of what could be going on with it. We didnt see any leaks at the water pump or pulley, but heard that its possible that the bearings could have just worn out and need replacing. My father has been saying that the hoses felt soft and as if no water had been flowing thru.
__________________
Powered by Yahoo! Answers
  #2
Guy I Guy I is offline
Junior Member
Default
So you saying it is getting HOT and the radiator is still cold. Who put in the thermostat? You know there is a certain direction to install the thermostat. It is actually stamped right on the thermostat itself telling which side should be facing the radiator. It seems like no coolant is circulating to the radiator now. Also you do not have to worry about the car heating up, but only need to worry if it gets into the red.
You pu in a new thermostat so it will run hotter than before because the old one was junk. So if it is just running warmer that is ok, but if it overheats (RED) you have a problem.
__________________
  #3
Old 02-04-2009, 10:34 AM
travelgirl218 travelgirl218 is offline
Junior Member
Default
I used to have a 98 Cavalier Z24 and I had an over heating problem while it was idling.. you may want to check the O2 sensor, seemed that was my problem.
Good luck
__________________
  #4
tallbrian1000 tallbrian1000 is offline
Junior Member
Default
The cooling system is air bound, you need to open the bleeders and let the air out and refill the coolant.
__________________
  #5
Old 02-04-2009, 10:55 AM
pendleton4068 pendleton4068 is offline
Junior Member
Default
upgrade the entire cooling system
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisements
Powered by vBulletin® Version 3.8.9
