chevy forums   chevy forums
Go Back   Chevy Forums > Chevy Forums - Cars > Chevy Impala Forum
Notices
Chevy Impala Forum Discussions regarding the Chevrolet Impala
Chevy Forum: my 06 impala engine is stalling..
Reply
Thread Tools
  #1
Old 02-21-2013, 07:49 AM
xbsx1 xbsx1 is offline
Junior Member
Default my 06 impala engine is stalling..
i have a 2006 impala SS 5.3L
my problem is im having trouble with it stalling and sometimes shuddering when i go to take off from a stop..
first thing i noticed a leak when i changed my oil one day
and come to find out my rear main gasket was leaking. so they replaced it
ever since then my car has been stalling out (loses power steering cant turn, but lights on dash and everything seem to work just engine dies) and the other problem is the shuddering..when i take off from a stop light stop sign ect...
i have cleaned my maf throttle body and cleaned my fuel injectors. still all problems after "chevy dealer" told me those were the causes...the problem still happened.. so i took it to a different chevy dealer they said crankshaft position sensor.. so the last thing i have had done was my crankshaft position sensor replaced along with the pigtail with it. AND it is still doing it..
has anyone had same problem or know of anything else that could possible be causing my shuddering or stalling problems?
any ideas or solutions would be appreciated. im at a lost to were to go.. no more ideas.
thanks everyone.
  #2
Old 02-21-2013, 10:50 AM
zora zora is offline
Administrator
Default Re: my 06 impala engine is stalling..
Is your check engine light on, if so you can have it scanned for free at autozone and then post the code here.
  #3
Old 02-21-2013, 11:03 AM
Junior Member
Theres no check engine light that comes on..that's why the "Chevy dealer" seemed stumped
  #4
Old 02-21-2013, 01:35 PM
Administrator
Have you ever changed your fuel filter? Have you checked the condition of your air filter? Has anybody checked fuel pressure?
  #5
Old 02-21-2013, 01:50 PM
Junior Member
Nope not to my knowledge they had me run flight recorder for a week and said only thing they seen was my crankshaft positon sensor fell off on the reading.. but they replaced still doing the same taking it back tomorrow guess ill have them check my fuel pressure
  #6
Old 02-21-2013, 02:03 PM
Administrator
If you still have no resolution to your problem contact GM customer service. The number is in the back of the owners manual. If you need a copy let me know.
  #7
Old 02-21-2013, 02:07 PM
Junior Member
I will need the number my car is in the shop I'm in a rental I would appreciate it
  #8
Old 02-21-2013, 03:19 PM
Administrator
Here is a link to your manual and the number is 1-800-222-1020
http://www.extendedgmwarranty.com/ow...let-Impala.pdf
  #9
Old 02-21-2013, 03:38 PM
Junior Member
Thank you I appreciate it
  #10
Old 02-22-2013, 08:18 AM
Chuzz Chuzz is offline
Senior Member
You sure it was your rear main seal leaking and not your torque converter/front pump seal? This sounds more like a transmission torque converter problem to me. If the tc isn't releasing from lock up, this can happen. Maybe if you can find the torque converter lock up switch connector, try unplugging it and see if that helps. If so, you have your answer. The switches don't cost all that much, but the labor to replace them is high.
__________________
"It's only when you see a mosquito landing on your testicles that you realize that there is always a way to solve problems without using violence."
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisements
Powered by vBulletin® Version 3.8.8
No special deals available at this time...
