chevy forums   chevy forums
Go Back   Chevy Forums > Chevy Forums - Cars > Chevy Cavalier Forum
Notices
Chevy Cavalier Forum Discussions regarding the Chevrolet Cavalier
Chevy Forum: 2004 Chevy Cavalier Broken Rocker Arms
Reply
Thread Tools
  #1
Old 08-27-2012, 09:29 PM
eibarra914 eibarra914 is offline
Junior Member
Default 2004 Chevy Cavalier Broken Rocker Arms
My fiance's Chevy Cavalier stopped working from one day to the next. The engine had just had it's oil changed three weeks prior so I doubt the engine ran without oil. Upon inspecting the cylinder head I noticed that two rocker arms where broken. I replaced the rocker arms, but still no start. I then check the battery and alternator, and both were bad so I replaced them. After this I thought it would work, but still no start although better sounding than before. I proceeded to check the spark plugs and the spark plug electrodes were all bent with absolutely no gap at all. I then changed the spark plugs, but still no start. I then opened the cylinder head again and this time six rocker arms were broken along with two bent spark plugs which I just had installed. At this point I'm not sure what to make of this. I either think the lifters are bad, the timing chain is off, or the valves are bent, but I don't know where to go from here.
  #2
Old 08-28-2012, 09:36 AM
zora zora is offline
Administrator
Default Re: 2004 Chevy Cavalier Broken Rocker Arms
Your timing chain is either broken or skipped a tooth and the pistons are slamming into the plugs.
  #3
Old 08-28-2012, 02:12 PM
Junior Member
Do you think that the pistons or valves have been damaged?
  #4
Old 08-28-2012, 02:35 PM
Administrator
you have to pull the head to determine that. Since you know you have broken rockers I would guess the valves are bent by now.
  #5
Old 08-29-2012, 09:31 PM
84chevycavalier 84chevycavalier is offline
Member
Before u pull the head, remove each pushrod and check them to see if there out of wack
  #6
Old 08-30-2012, 04:28 PM
Junior Member
I haven't done that yet, but I will give it a try. Are the push rods under the rocker arms, and how are they supposed to feel?
  #7
Old 08-30-2012, 04:57 PM
Administrator
The pushrods push the rocker arm against the valve stem. The pushrods are supposed to be perfectly straight. If you roll them on something like a flat piece of glass they should not wobble.
  #8
Old 08-31-2012, 11:59 AM
Member
If some are bent, napa has them for around 5 dollars a,piece and id recomened doin all 8 at the same time
Reply
Tags
cylinder head, rocker arms, spark plugs
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisements
Powered by vBulletin® Version 3.8.9
