chevy forums   chevy forums
Go Back   Chevy Forums > Chevy Forums - Trucks, SUVs and Crossovers > Chevy Equinox Forum
Notices
Chevy Equinox Forum Discussions regarding the Chevrolet Equinox
Chevy Forum: Put green coolant/antifreeze in dexcool system (2005 chevy equinox)?
Reply
Thread Tools
  #1
Old 05-22-2010, 10:20 AM
MIKE MIKE is offline
Senior Member
Default Put green coolant/antifreeze in dexcool system (2005 chevy equinox)?
My equinox started overheating, checked the coolant and it was empty so I went and got some. I must not have been thinking I just grabbed a gallon of peak green af/coolant, put it in there, and has been running fine. I noticed my temperature gauge wouldn't go halfway, right under it so I tried to figure out what was up.
Anyways, later I checked the coolant cap and it said DEXCOOL coolant only. Which is the red stuff.
I'm car retarded, so what does this mean? Did I just ruin my engine? I hope I didn't... because this is a company vehicle. Would probably lose my job if I destroyed the engine.
Thank you
__________________
Powered by Yahoo! Answers
  #2
Old 05-22-2010, 10:21 AM
Cobra1 Cobra1 is offline
Junior Member
Default
No,the engine is not ruined. Mixing the two antifreeze together will mess up your thermostat,it will hang open and not heat water properly or hang closed and overheat. Have cooling system flushed out,change thermostat,refill with recommended antifreeze.Will take care of your problem. Please make sure you put in new thermostat.
__________________
  #3
Old 05-22-2010, 10:24 AM
mudpuppy72 mudpuppy72 is offline
Junior Member
Default
Typically the red (dexcool) and the green are not compatible and they cause corrosion if mixed together. I would suggest getting it to a place where they can flush the cooling system and having it refilled with dexcool. There is a yellow coolant now that is compatible with all other types of coolant. Most Jiffy lubes can flush your cooling system. Done soon it should not cause any damage.
__________________
  #4
Old 05-22-2010, 10:30 AM
Freedom Wins IV Freedom Wins IV is offline
Junior Member
Default
Get rid of the DEXCOOL as it will cause problems as the car gets older. Shyt turns to mud in the heater core when it sits over the summer.
I changed my '01 Blazer over to the "green" AFTER I had to replace two heater cores in two years as they were plugged up with the Dexcool. Never had a problem after I changed it over with either the core plugging up or with cooling!! Temps never went over 200 for 100,000 miles and I pulled a 2600# boat with it during the heat of the summer in Arkansas and Texas.
Just my humble opinion!
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisements
Powered by vBulletin® Version 3.8.8
No special deals available at this time...
