chevy forums   chevy forums
Go Back   Chevy Forums > Chevy Forums - Trucks, SUVs and Crossovers > Chevy Silverado Forum
Chevy Silverado Forum Discussions regarding the Chevrolet Silverado
andy's auto sport
Reply
Thread Tools
  #1
Old 02-11-2010, 11:46 PM
Erika Erika is offline
Junior Member
Default 2002 Chevrolet Silverado 2500HD 4x4. it has a 6.0L with a 4L80E. I’m having
transmission trouble.? Hi, My name is Robert. I have a 2002 Chevrolet Silverado 2500HD 4x4. it has a 6.0L with a 4L80E. I’m having transmission trouble.Here’s what’s happened. it’s been slowly getting worse. The truck would take a long time to go into gear like it was slipping. Eventually, it stopped going into gear altogether. You could put it any gear and the motor would just rev. if you let it set for a day it would go into gear and you could drive for about 3 minutes and then if you stopped or slowed down, then the motor would just rev and you went no where. I was told my torque converter went bad, so I replaced that. it did nothing, truck did the same thing. i was then told it might be the pump. I didn’t have a pressure gage so i was told if I take off one of the cooler lines at the radiator trans fluid should come out with the truck running. nothing. so i took the pump apart and there was a build up of fine metal blocking a channel. the pump also has some wear under the gears that rotate in the pump. I cleaned it all up, put it together and my trucked moved again for about three minutes and the then same bullshit. I don’t know what it is, seems like something between the tc and the pump, but i’m out of ideas, please help!
__________________
Powered by Yahoo! Answers
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
chevyforum.org recognizes that "Chevy", "Chevrolet", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. chevyforum.org is not affiliated in any way with the General Motors Corporation, Chevy, Chevrolet or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2012 Madison Ross Media Group. All rights reserved. Content published on ChevyForum.org requires permission for reprint.
Chevy Headlights at Andy's | Chevy Tail Lights | Chevy Intake
