chevy forums   chevy forums
andys auto sport
Go Back   Chevy Forums > Chevy Forums - Cars > Chevy Cobalt Forum
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Chevy Cobalt Forum Discussions regarding the Chevrolet Cobalt
Reply
Thread Tools
  #1
Old 02-08-2010, 01:12 PM
Met fanatic Met fanatic is offline
Junior Member
Default i have a p0300 code coming up on my 2006 chevy cobalt. what can i do?
i have been having issues with this car for the longest time. my car idle jumps up and down, and when i'm in park i hit the gas for a slight rev. and the idle drops very low and the headlight dim as if the car is gonna die/turn off. Sometimes i'll start the car and the drive is rough and a few feet later when i stop or slow down or when i go in reverse my car turns off. especially when gas is low its at its worst. my car sometimes will turn off after i hit a right/left turn and i go to push on the gas and it cuts off. although everytime it happens it starts right up again....someone please help!!!!!
__________________
Powered by Yahoo! Answers
  #2
Old 02-08-2010, 01:13 PM
bandit_60 bandit_60 is offline
Senior Member
Default
po300 is a cylinder misfire. it could be a bad plug wire, the cap and rotor or if you don,t have a distributor the coil pack. it also could be a plug misfiring.
__________________
  #3
Old 02-08-2010, 01:17 PM
Frankie Frankie is offline
Junior Member
Default
There are many causes for this obd code. Since it is a "random misfire" or "multiple misfire" this means that the misfire is on different cylinders and not just one all the time. This means that the most likely causes are things like:
Low Fuel Pressure
Vacuum Leak
EGR system malfunction
Internal Engine Problems (such as low compression)
BUT other things that can cause this code are:
Faulty Coil
Faulty Spark Plugs and/or Wires
Camshaft or Crankshaft sensors
Ignition module
Computer
The first thing I would do if the problem wasn't obvious by inspection is a full tune up. Many times this will fix this code. If you want to do more diagnosis so you don't just throw parts at it you will need to check each of the above items starting with the top four.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.12
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
chevyforum.org recognizes that "Chevy", "Chevrolet", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. chevyforum.org is not affiliated in any way with the General Motors Corporation, Chevy, Chevrolet or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2008 Madison Ross Media Group. All rights reserved. Content published on ChevyForum.org requires permission for reprint.
custom floor mats | air suspension kits | air suspension parts | chevy camaro exhaust | chevy s10 exhaust | chevy s10 tonneau cover | chevy camaro wheels | chevy camaro headers | chevy silverado wheels
